I use this config file for twitter input.But its not creating index in Elastic Search.
When i run this config file for first time its created index.But next time when i want to create new index by using same config file its not creating index.
I use this config file file for twitter input.But its not crating index in Elastic Search.
When i run this config file its created index.But next time when i run config file its not creating index.
The index name is fixed to "twitter12", so unless you're deleting the index between the Logstash invocations I don't understand what you mean by this.
I given a different name index for 2nd time.
And then it works?
I try to create sincedb file but its showing me error when i run config file.
Why would you create a sincedb file? What error do you get?
logo are trademarks of the
Apache Software Foundation
