Not able to monitor with Metricbeat. Monitoring with Self monitoring in kibana
I have configured metricbeat in windows providing you the steps I followed.
  1. kibana -> stack monitoring -> monitor with metricbeat -> followed the steps mentioned there -> downloaded and setup metricbeat. -> changed the output.elasticsearch configuration in metricbeat.yml -> enabled elasticsearch xpack .yml -> edit elasticsearch xpack .yml configuration -> changed cluster settings -> start metric beat -> monitor with metricbeat from kibana.
but still I am not able to monitor it with metric beat. it is self monitoring. on the other hand my kibana instance is monitoring fine with metricbeat.
my cluster setting:
"persistent": {
"xpack": {
"monitoring": {
"elasticsearch": {
"collection": {
"enabled": "false"
"collection": {
"enabled": "true"
"transient": {}
Please share your metricbeat.yml
Did you enable monitoring in metricbeat.yml?
# Set to true to enable the monitoring reporter.
#monitoring.enabled: false
to
monitoring.enabled: true
yes i have enabled it...
this is my metricbeat yml file
###################### Metricbeat Configuration Example #######################
# This file is an example configuration file highlighting only the most common
# options. The metricbeat.reference.yml file from the same directory contains all the
# supported options with more comments. You can use it as a reference.
# You can find the full configuration reference here:
# https://www.elastic.co/guide/en/beats/metricbeat/index.html
# =========================== Modules configuration ============================
metricbeat.config.modules:
  reload.enabled: false
  #reload.period: 10s
# ======================= Elasticsearch template setting =======================
setup.template.settings:
  index.number_of_shards: 1
  index.codec: best_compression
  #_source.enabled: false
# ================================== General ===================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name:
# The tags of the shipper are included in their own field with each
# transaction published.
# Optional fields that you can specify to add additional information to the
# output.
#fields:
#  env: staging
# ================================= Dashboards =================================
# These settings control loading the sample dashboards to the Kibana index. Loading
# the dashboards is disabled by default and can be enabled either by setting the
# options here or by using the `setup` command.
#setup.dashboards.enabled: false
# The URL from where to download the dashboards archive. By default this URL
# has a value which is computed based on the Beat name and version. For released
# versions, this URL points to the dashboard archive on the artifacts.elastic.co
# website.
#setup.dashboards.url:
# =================================== Kibana ===================================
# Starting with Beats version 6.0.0, the dashboards are loaded via the Kibana API.
# This requires a Kibana endpoint configuration.
setup.kibana:
  # Kibana Host
  # Scheme and port can be left out and will be set to the default (http and 5601)
  # In case you specify and additional path, the scheme is required: http://localhost:5601/path
  # IPv6 addresses should always be defined as: https://[2001:db8::1]:5601
  #host: "localhost:5601"
  # Kibana Space ID
  # ID of the Kibana Space into which the dashboards should be loaded. By default,
  # the Default Space will be used.
  #space.id:
# =============================== Elastic Cloud ================================
# These settings simplify using Metricbeat with the Elastic Cloud (https://cloud.elastic.co/).
# The cloud.id setting overwrites the `output.elasticsearch.hosts` and
# `setup.kibana.host` options.
# You can find the `cloud.id` in the Elastic Cloud web UI.
#cloud.id:
# The cloud.auth setting overwrites the `output.elasticsearch.username` and
# `output.elasticsearch.password` settings. The format is `<user>:<pass>`.
#cloud.auth:
# ================================== Outputs ===================================
# ---------------------------- Elasticsearch Output ----------------------------
output.elasticsearch:
  hosts: ["localhost:9200"]
  # Protocol - either `http` (default) or `https`.
  protocol: "https"
  username: "user"
  password: "mypassword"
  # Authentication credentials - either API key or username/password.
  #api_key: "id:api_key"
  #username: "elastic"
  #password: "changeme"
  ssl:
    enabled: true
    ca_trusted_fingerprint: "ca-fingerprint"
# ------------------------------ Logstash Output -------------------------------
#output.logstash:
  # The Logstash hosts
  #hosts: ["localhost:5044"]
  # Optional SSL. By default is off.
  # Client Certificate Key
# ================================= Processors =================================
# Configure processors to enhance or manipulate events generated by the beat.
processors:
  - add_host_metadata: ~
  - add_cloud_metadata: ~
  - add_docker_metadata: ~
  - add_kubernetes_metadata: ~
# ================================== Logging ===================================
# Sets log level. The default log level is info.
# Available log levels are: error, warning, info, debug
#logging.level: debug
# At debug level, you can selectively enable logging only for some components.
# To enable all selectors use ["*"]. Examples of other selectors are "beat",
# "publisher", "service".
#logging.selectors: ["*"]
# ============================= X-Pack Monitoring ==============================
# Metricbeat can export internal metrics to a central Elasticsearch monitoring
# cluster.  This requires xpack monitoring to be enabled in Elasticsearch.  The
# reporting is disabled by default.
# Sets the UUID of the Elasticsearch cluster under which monitoring data for this
# Metricbeat instance will appear in the Stack Monitoring UI. If output.elasticsearch
# is enabled, the UUID is derived from the Elasticsearch cluster referenced by output.elasticsearch.
#monitoring.cluster_uuid:
# Uncomment to send the metrics to Elasticsearch. Most settings from the
# Elasticsearch output are accepted here as well.
# Note that the settings should point to your Elasticsearch *monitoring* cluster.
# Any setting that is not set is automatically inherited from the Elasticsearch
# output configuration, so if you have the Elasticsearch output configured such
# that it is pointing to your Elasticsearch monitoring cluster, you can simply
# uncomment the following line.
monitoring.elasticsearch:
# ============================== Instrumentation ===============================
# Instrumentation support for the metricbeat.
#instrumentation:
    # Set to true to enable instrumentation of metricbeat.
    #enabled: false
    # Environment in which metricbeat is running on (eg: staging, production, etc.)
    #environment: ""
    # APM Server hosts to report instrumentation results to.
    #hosts:
    #  - http://localhost:8200
    # API Key for the APM Server(s).
    # If api_key is set then secret_token will be ignored.
    #api_key:
    # Secret token for the APM Server(s).
    #secret_token:
# ================================= Migration ==================================
# This allows to enable 6.7 migration aliases
#migration.6_to_7.enabled: true
elasticsearch-xpack.yml
# Module: elasticsearch
# Docs: https://www.elastic.co/guide/en/beats/metricbeat/8.3/metricbeat-module-elasticsearch.html
- module: elasticsearch
  xpack.enabled: true
  period: 10s
  hosts: ["https://localhost:9200"]
  username: "user"
  password: "password"
  ssl.enabled: true
  ssl.certificate_authorities: ["C:\Program Files\Metricbeat\data\ca_1665559367493.crt"]
  #ssl.verification_mode: "certificate"
kibana-xpack.yml
# Module: kibana
# Docs: https://www.elastic.co/guide/en/beats/metricbeat/8.3/metricbeat-module-kibana.html
- module: kibana
  xpack.enabled: true
  period: 10s
  hosts: ["localhost:5601"]
  #basepath: ""
  username: "user"
elasticsearch.yml
# ======================== Elasticsearch Configuration =========================
# NOTE: Elasticsearch comes with reasonable defaults for most settings.
#       Before you set out to tweak and tune the configuration, make sure you
#       understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.elastic.co/guide/en/elasticsearch/reference/index.html
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
#cluster.name: my-application
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
#node.name: node-1
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
#path.data: /path/to/data
# Path to log files:
#path.logs: /path/to/logs
#Path to snapshot directory
path.repo: ["C:/Users/user/Desktop/Snapshort-AdvanceSearch"]
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# By default Elasticsearch is only accessible on localhost. Set a different
# address here to expose this node on the network:
#network.host: 192.168.0.1
# By default Elasticsearch listens for HTTP traffic on the first free port it
# finds starting at 9200. Set a specific HTTP port here:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when this node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
#discovery.seed_hosts: ["host1", "host2"]
# Bootstrap the cluster using an initial set of master-eligible nodes:
#cluster.initial_master_nodes: ["node-1", "node-2"]
# For more information, consult the discovery and cluster formation module documentation.
# --------------------------------- Readiness ----------------------------------
# Enable an unauthenticated TCP readiness endpoint on localhost
#readiness.port: 9399
# ---------------------------------- Various -----------------------------------
# Allow wildcard deletion of indices:
#action.destructive_requires_name: false
#----------------------- BEGIN SECURITY AUTO CONFIGURATION -----------------------
# The following settings, TLS certificates, and keys have been automatically
# generated to configure Elasticsearch security features on 31-08-2022 07:18:58
# Enable security features
xpack.security.enabled: true
xpack.security.enrollment.enabled: true
# Enable encryption for HTTP API client connections, such as Kibana, Logstash, and Agents
xpack.security.http.ssl:
  enabled: true
  keystore.path: certs/http.p12
# Enable encryption and mutual authentication between cluster nodes
xpack.security.transport.ssl:
  enabled: true
  verification_mode: certificate
  keystore.path: certs/transport.p12
  truststore.path: certs/transport.p12
# Create a new cluster with the current node only
# Additional nodes can still join the cluster later
cluster.initial_master_nodes: ["DESKTOP-PAD6FDG"]
# Allow HTTP API connections from anywhere
# Connections are encrypted and require user authentication
http.host: 0.0.0.0
# Allow other nodes to join the cluster from anywhere
# Connections are encrypted and mutually authenticated
#transport.host: 0.0.0.0
#switching off the self monitoring for elasticsearch
xpack.monitoring.collection.enabled: true
xpack.monitoring.elasticsearch.collection.enabled: false
#----------------------- END SECURITY AUTO CONFIGURATION -------------------------
Can you try commenting that out.
I'm a little confused so you first turned on self monitoring and now you're trying to go to metricbeat monitoring?
I'm also a little confused on. Are you trying to monitor Elasticsearch or metricbeat itself or both?
I am trying to monitor elasticsearch instance with metricbeat.
Also tried with switching off that line monitoring.elasticsearch nothing happened.
Yes I turned on self monitoring and now I am trying to go to metricbeat monitoring.
Did you actually look at the metricbeat logs to make sure it is started and connected to elasticsearch OK?
this is my metricbeat index that was created
