Hi, i have two index in elastic cloud
Added the new role for a custom dashboard
Created and configured roled with index "chiporro"
Created user and assigned role
When I log in to user test1, I can't see the dashboards (they exist with that index) and I can't do anything.
I need your help, I would appreciate it
Fabian
TimV
(Tim Vernum)
August 3, 2018, 12:48am
2
If you look at the definition for kibana_dashboard_only_role you'll see that it has specific access:
GET /_xpack/security/role/kibana_dashboard_only_user
"kibana_dashboard_only_user" : {
"cluster" : [ ],
"indices" : [
"names" : [
".kibana*"
"privileges" : [
"read",
"view_index_metadata"
"run_as" : [ ],
"metadata" : {
"_reserved" : true
"transient_metadata" : {
"enabled" : true
Your test_dashboard_only_user needs to grant that same access to .kibana
Hi, apparently I have the same accesses in the role test_dashboard_only_user
is rare
