Visual Builder > Removing Axis Min and Axis Max sets min=0 max=1
There seems to be a bug that when you remove the Axis Min and Axis Max in VB it's set to 0-1.
After setting the Separate axis = F the min/max is set based on the data correctly, but setting Separate axis = T back will break it again (min-max = 0-1).
Hi @Ludek_Sanda
Welcome to Discuss forum!
Can you add stack version and attach screenshots before/after the last step?
Regards, Dzmitry
Hi @Dzmitry,
version 6.8.12.
But never mind...I can not reproduce it anymore even in the original visualisation (was able to reproduce it even on a fresh new with various settings).
