Hi guys
I'm facing a problem trying to render all the information on the screen, I'm getting "..This container is too small to render the visualization.." so I came up with the idea to create separate dashbords for every node instead of trying to display all of them in a single graphic, so , my question is, how can I do that, be able to create an area chart for example, for CPU usage over time and say, apply THIS chart to THIS host only..
Thanks for your time and support
Regards
