Kibana Index Pattern Configuration Problem
I configured Logstash as follows:
file { path => "/var/log/apache2/access.log" }
grok {
match => { "message" => "%{COMBINEDAPACHELOG}" }
date {
    match => [ "timestamp", "dd/MMM/yyyy:HH:mm:ss Z" ]
mutate {
    convert => {
        "response" => "integer"
        "bytes" => "integer"
hosts => "localhost:9200"
index => "apache-%{+YYYY.MM.dd}"
I installed and configured Apache.
When I try to configure the index in Kibana, I get the following message: The index pattern I set does not match any data stream.
I don't know where the problem lies.
Can you please help me?
Hi @Pacous,
Welcome back! It looks like it's expecting data stream settings. Can you change your configuration to use the data stream settings, similar to the below example:
    hosts => ["https://your-elasticsearch-host:9200"]
    data_stream => true
    data_stream_type => "logs"         # or metrics, etc.
    data_stream_dataset => "app"
    data_stream_namespace => "default"
Let us know if that works.
Hi Carly,
I applied the configuration you provided.
I still can't see the index on Kibana.
file {
start_position => "beginning"
sincedb_path => "/dev/null"
grok {
match => {
date {
    match => [ "timestamp" , "dd/MMM/yyyy:HH:mm:ss Z" ]
hosts => ["https://localhost:9200"]
index => "apache-access-%{+YYYY.MM.dd}"
data_stream => true
Ok, can can share the output of the latest logs? Are there Ny changes/ new errors in there?
Hi Carly,
When i do the following command m,
sudo /usr/share/logstash/bin/logstash --path.settings /etc/logstash -f /etc/logstash/conf.d/apache.conf -t
I have the following result,
[2026-06-19T13:47:25,624][INFO ][logstash.javapipeline ] Pipeline main is configured with pipeline.ecs_compatibility: v8 setting. All plugins in this pipeline will default to ecs_compatibility => v8 unless explicitly configured otherwise.
Configuration OK
[2026-06-19T13:47:25,837][INFO ][logstash.runner ] Using config.test_and_exit mode. Config Validation Result: OK. Exiting Logstash
When i do the following command,
sudo /usr/share/logstash/bin/logstash --debug --path.settings /etc/logstash -f /etc/logstash/conf.d/apache.conf
[2026-06-19T13:58:00,883][ERROR][logstash.javapipeline ][main] Pipeline error {:pipeline_id=>"main", :exception=>"LogStash::ConfigurationError", :error=>"Invalid data stream configuration: ["index"]", :stacktrace=>"/usr/share/logstash/vendor/bundle/jruby/3.1.0/gems/logstash-output-elasticsearch-11.22.15-java/lib/logstash/outputs/elasticsearch/data_stream_support.rb:76:in check_enabled_data_stream_config!'\n/usr/share/logstash/vendor/bundle/jruby/3.1.0/gems/logstash-output-elasticsearch-11.22.15-java/lib/logstash/outputs/elasticsearch/data_stream_support.rb:59:in check_data_stream_config!'\n/usr/share/logstash/vendor/bundle/jruby/3.1.0/gems/logstash-output-elasticsearch-11.22.15-java/lib/logstash/outputs/elasticsearch/data_stream_support.rb:32:in data_stream_config?'\n/usr/share/logstash/vendor/bundle/jruby/3.1.0/gems/logstash-output-elasticsearch-11.22.15-java/lib/logstash/outputs/elasticsearch.rb:305:in register'\norg/logstash/config/ir/compiler/AbstractOutputDelegatorExt.java:69:in register'\n/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:243:in block in register_plugins'\norg/jruby/RubyArray.java:1981:in each'\n/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:242:in register_plugins'\n/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:610:in maybe_setup_out_plugins'\n/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:255:in start_workers'\n/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:196:in run'\n/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:148:in block in start'", "pipeline.sources"=>["/etc/logstash/conf.d/apache.conf"], :thread=>"#<Thread:0x17ecf057 /usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:138 run>"}
[2026-06-19T13:58:00,895][INFO ][logstash.javapipeline ][main] Pipeline terminated {"pipeline.id"=>"main"}
[2026-06-19T13:58:01,090][ERROR][logstash.agent ] Failed to execute action {:id=>:main, :action_type=>LogStash::ConvergeResult::FailedAction, :message=>"Could not execute action: PipelineAction::Create, action_result: false", :backtrace=>nil}
[2026-06-19T13:58:01,102][DEBUG][logstash.agent ] Shutting down all pipelines {:pipelines_count=>0}
[2026-06-19T13:58:01,126][DEBUG][logstash.agent ] Converging pipelines state {:actions_count=>0}
[2026-06-19T13:58:01,129][DEBUG][logstash.instrument.periodicpoller.os] Stopping
[2026-06-19T13:58:01,130][DEBUG][logstash.instrument.periodicpoller.jvm] Stopping
[2026-06-19T13:58:01,130][DEBUG][logstash.instrument.periodicpoller.persistentqueue] Stopping
[2026-06-19T13:58:01,134][DEBUG][logstash.instrument.periodicpoller.deadletterqueue] Stopping
[2026-06-19T13:58:01,198][DEBUG][logstash.instrument.periodicpoller.flowrate] Stopping
[2026-06-19T13:58:01,236][DEBUG][logstash.agent ] API WebServer has stopped running
[2026-06-19T13:58:01,241][INFO ][logstash.runner ] Logstash shut down.
[2026-06-19T13:58:01,332][FATAL][org.logstash.Logstash ] Logstash stopped processing because of an error: (SystemExit) exit
org.jruby.exceptions.SystemExit: (SystemExit) exit
at org.jruby.RubyKernel.exit(org/jruby/RubyKernel.java:924)
at org.jruby.RubyKernel.exit(org/jruby/RubyKernel.java:883)
at usr.share.logstash.lib.bootstrap.environment.(/usr/share/logstash/lib/bootstrap/environment.rb:90)
Remove the index configuration from your output, you have set data_stream to true and all other data_stream_* settings, the index configuration cannot be used when data_stream is true.
Try changing to this:
data_stream => true
What do I do in Kibana to view the logs?
Since I'm using the index, I configure the same index in Kibana that I configured in Logstash.
Data streams sit on top of indexes, so you view them in the same way. If you can't see your logs in Kibana discover it's because you need to create a data view on top.
I still don't see any logs, as you can see from the screenshot.
I think these are completely different things.
In your original question you asked this:
How did you try to configure it and what is the name of the index you have in Elastic? Can you see your Index when you go into Stack management > Index management?
Please share some screenshots showing if you have any index starting with apache-*
You said to remove the index entry in Logstash.
Otherwise, here's the configuration I had:
data_stream => true
This configuration will not work, you cannot have both index and data_stream => true at the same time.
If you had only index => "apache-access-%{+YYYY.MM.dd}" your log should go into an index named something like apache-2026-06-19
And in Kibana in need to create a Data View looking to apache-*.
If you use something like this:
data_stream => true
Then your data will be on logs-app-default and your Data View needs to look at logs-app-*.
In your first question you had only the index configuration, with this did you had any apache-* index? After changing it to write into data stream did you had any logs-app-* index written?
You can check going into Stack Management > Index Management and looking both in the index and data streams tab.
Here is the result shown in the screenshot when I try to configure the index on Kibana:
