I have two elastic search clusters ( distributed in two physical sites ). These clusters are working fine with logstash and kibana individually. For now, I am trying to replicate this in a single machine. Each of the clusters is having single elasticsearch nodes. I need to provide a view from Kibana that will consider the data from both the sites.
Seeing the documentation of tribe nodes, it appears to me that tribe can help me to achieve the objective, without replication of data between the sites. I want to avoid the data replication across sites(different clusters), to get rid of the network overhead. My tribe node configuration in elasticsearch.yml is as below:
t1:
cluster.name: cluster1
discovery.zen.ping.multicast.enabled: false
discovery.zen.ping.unicast.hosts: ["localhost:9201"]
t2:
cluster.name: cluster2
discovery.zen.ping.unicast.hosts: ["localhost:9202"]
In host1 and host2 elasticsearch.ymls, I have un-commented only the following lines:
For 1st elasticsearch
node.name: node-1
http.port: 9201
For 2nd elasticsearch
node.name: node-2
http.port: 9202
When I use Kibana with the tribe node, it does not show any result. Am I missing anything?
Strangely the console of the tribe node shows a reference to port 9302 as below, Not sure how it is getting reference to 9302:
[2015-12-24 23:04:26,481][INFO ][transport ] [Bova] publish_address {127.0.0.1:9302}, bound_addresses {127.0.0.1:9302}, {[::1]:9302}
