[Vega/EMS] Problems using EMS map World Countries
Trying to use the World Countries map from the EMS Boundaries with Vega like it's shown in the documentation here.
The (very simple) code is the following under Kibana 7.16.3:
  $schema: https://vega.github.io/schema/vega/v5.json
  config: {
    kibana: {type: "map"}
  data: [
      url: {
        %type%: emsfile
        name: World Countries
      format: {property: "features"}
I'm getting this message:
Data ingestion failed
"url": "https://vector.maps.elastic.co/files/world_countries_v7.topo.json?elastic_tile_service_tos=agree&my_app_name=kibana&my_app_version=7.16.3&license=sspl"
Works with other maps (France Departments, Albania Counties or Andorra Parishes for example).
Anyone has an idea what the problem might be or how to find it's source?
Thanks.
Regards.
Thanks for reporting. I have opened an issue [maps][vega] Unable to use topojson EMS boundary layers · Issue #130461 · elastic/kibana · GitHub to track the problem.
Thanks.
Used the corrected syntax mentioned here and it works.
Regards.
